mattnj
Hi,
I have a generator I am trying to get running (bought it as a non runner) it is a yanmar 3TNE68 3 cylinder 17hp I think. If I let the plugs heat then crank it runs everytime for about 1second. If I try immediately to restart it stutters and never runs, sounds like it's trying on 1 cylinder and turns over assisting the starter motor.
If I leave for about 1min the plugs heat again and it does the same thing (runs ok for about 1sec)
I have replaced the fuel, bled it to death, replaced filters, no difference. If I remove the 3 connections to the injectors there appears to be a healthy squirt coming out of each connector although if I disconnect the return from injectors and crank nothing comes out of that which seems a bit odd?
And ideas anyone on what to look at next?
Other thing worth mentioning is that it appeared to over overfilled with oil by about 1" on the dipstick! Which I have now drained out.
Thanks.
Thanks.
