Interesting one. I would say as long as you can sail out of season it would be ok for 80% of the places I get into and all the main ones will be accessible.
You will be restricted to the deeper areas of quite a lot of tidal and sill marinas, outside of July and August this should not be a problem.
Most of Brittany is deep water then rock!! so 2.2m is the same as my 1.2m with the keel up when on passage! Where the restriction affects you is getting onto the bouy in the Erchou Islands, some shallower overtide anchorages in Morbihan, Etal, going up rivers to Totnes etc, anchoring close inshore in Scilly Islands etc etc
You need to decide whether performance sailing or coastal cruising is primordial for you - if you have the choice. 2m2 is a bit of a hindrance but not that much. I know that in some of the places I go I have some anxious moments with 1m70 ; I simply would exclude those places with a deeper draft.
Westcountry & Brittany work benefits from deep keels IMHO.
If your looking at an AWB they are usually better for deeper keels.
Your windward performance should benefit. Particularly if deeper keel means deeper rudder. Big tides and changable weather mean that a bit more passage speed is always useful. You'll have to hang about outside a few marina sills for an extra 15mins or so but unless you go very shallow it's not much of a difference.
When a yacht builder offers a choice it's to increase the marketplace, to those who need the shallow draft, not to improve the marque.
When designers are asked to design a yacht the deeper keel would be nearer to optimum for the hull shape.
Some shallow draft yachts are complete dogs by comparison to their deep keel brothers, I'm thinking of one in particular from the USA, usually the difference is not so marked but it is often quite clear.
I used to cruise the channel with 14ft (4m) of draught. Now that is a bit limiting.
It is a sporty AWB design.
I think the rudder is the same for either keel, but it is large - a teenager might describe the rudder as wicked.
I like this logic, I suppose I am looking for reasons to buy the 2.2m version. 15 minutes is not much of a penalty for the satisfaction of sharp sailing characteristics.
How are your secondary port calculations, and allowance for pressure differences - this draught will certainly enable you to hone those skills. Personnally I think Mirabelle had the right idea for the deeper keel - if you want it deeper, press a button and the hydraulic rams push it down!
I visited Dieppe yesterday to view a yacht, one of the first of this new design to be fully commissioned in channel waters. (More on the model later next week once I have agreed a price and got my production slot booked).
The agent showed me around the yacht that had been handed over to its owner last weekend. After the agent left the French owner took me out for a 2 hour sail, which was an unexpected bonus.
We got 6 knots of boat speed in a light 9 knot (true) wind. This trial sail was the final push I needed so now it is down to the purchase options. I was warned off the 1.8m keel as the first one of these delivered elsewhere in Europe has been a tippy disappointment.
The yacht I sailed yesterday was the 2.2m version and I was impressed by how little she heeled with 3 bodies on the side deck approaching the pontoon. Logic says that because I will be using this racer/cruiser design as more of a cruiser/racer, the 2m option is right for me.
For those familiar with the vital statistics of AWB's, the numbers are:
Current boat has 2.2 - we're based in exactly they area you talk about (CI). I havent ever failed to get where I wanted to go because of lack of water.
I'm sure Pontrieux is achievable (I havent been there with the current boat as the rig is far too tall) - but the dredgers must draw about the same when laden.
The deeper keel will always be a better option when you are outside a harbour - and that is what a boat is for!
We draw 2.2 and it hasnt cramped our sailing - we do look at the harbour charts quite carefully, in particular not rushing in as soon as the lock opens. the only real problem we had was on entereing st Vaast where there is a rock just inside the entrance which has about 2.1 when the gates open but if you adopt a cautious approach its ok
