Yeoman_24
What size starter battery would you suggest for a 10 year old, start first time, reliable 28hp Beta Marine engine?
Thanks.
Thanks.
Thanks.
If you can get more CCA and more Ah for no more money, it might still start the engine easily for more years.
You're not wrong but to be a bit clearer....As has been pointed out, Ah is largely irrelevant for engine start batteries`. You need lots of momentary oomph, but very little capacity. (The opposite to domestic batteries.)
Ensure the CCA is at least what the manufacturer recommends. Add a bit to the CCA requirement so the battery will continue to be serviceable as it becomes aged, so won't need replacing so soon. Don't worry about the Ah, you'll never use it all.
