25mm prop on 1 " shaft.
tyce
6 Jan 2004
cumbria
Wanting to fit a 25mm prop to my 1 inch prop shaft, I am guessing it won't be an issue, has anyone any practical experience.
Thanks for info everyone, looks like there may be an issue, need to double check my shaft with a vernier.
On my little lathe, machining the shaft would be easier than the prop, as the set up is straight forward. If desperate, I would fit the prop with thickened epoxy to even out the tapers.
DW
