Cdicko
simply.............. 12 meter boat............. 25kg rockna or 20kg vulcan? )......... im not interested in views of size mainly design?? Advice?
Do they both fit on your bow roller? Furling gear can be located close to deck making roll bars a bit of a nuisance and sometimes the windlass is too close to the roller to allow the shank to be pulled far enough aft to house the fluke.
You seem to have already decided that Knox (locally made, I think UK steel), Viking (support Ukraine industry, Swedish steel), Epsilon (UK company, made in China), Spade (French, made in Tunisia) or Excel (Australian, made in Australia from Australian steel) are not for you - It would be interesting to know why they have each been rejected. I suspect you local chandler stocks both Rocna and Vulcan - not a reason buy either.
My conclusion on the motivation and inspiration for both Rocna and Vulcan - Peter Smith admired the Spade design and Rocna is a copy of Spade but with much cheaper and simpler manufacture. Later when patents became less of an issue he redesigned Rocna (bearing in mind his inspiration) and came up with Vulcan. In the interim Ultra also appear inspired by Spade and Epsilon (the most recent introduction) has not ignored Spade either (and may marry Spade, with the influence of the enduring success of convex (CQR, Delta, Kobra, Excel).
Spade, particularly, and Rocna are now quite old designs and design has moved forward. I think you would be happy with any of the anchors I mention (they will not let you down, and will all be easy and reliable to set,) but I would favour some of the newer designs which remove some of the niggles that detract from both Spade and Rocna. None of these designs, that I mention, will give you stellar performance in soupy mud (use a Fortress) - and you omit to mention your common seabeds. If you do anchor in mud - Rocna will allow you to sample the seabed every time your retrieve - and for this reason alone I would discount it. Most anchors will collect mud - Rocna is particularly bad - you would need a powerful deck wash. If weight might be an issue - I'd look at Viking, the Viking 15. If you consider a Viking you can add a Boomerang (to replace your swivel) and chain hook (for your snubber) to your purchase and save on freight costs (maybe you can persuade them to throw both items in as a sweetener - if you don't ask you will never know)..
I mention snubber as I don't think one buys an anchor in insolation - the ground tackle is a complete package which should be made up of compatible components.
When you get closer to deciding - take a couple of links of your chain to the anchor you intend to buy and ensure that you can source a sensible shackle that will be strong enough and fit both anchor slot and chain link. Unfortunately the best shackles remain those from Crosby and you may have to source mail order - but all, say 1/2" shackles, are the same size and if you find a 1/2" fits in the local chandler - then you can buy a 1/2" Crosby relatively easily. (I buy from Tecni in the UK - impossible to source cheaply in Oz).). If you have a local lifting gear supplier - Crosby bought Gunnebo (big in aquaculture) and Gunnebo are active across all of Europe - and if your local lifting gear supplied Gunnebo than they may hold Crosby shackles.
I'm not answering your question, apologies - but maybe offering you some alternative thoughts.
You will not go wrong with your restricted list and my slightly more 'modern' ideas.
Jonathan
How about a Knox? Made in Scotland.
We haven't had an anchor thread for a few days, this will be exciting. I do not profess to be an expert on the matter, but these are my thoughts:
I just got myself a 12kg Vulcan, to replace a 10kg Delta knockoff, even though my bow roller would accommodate a Rocna 10kg just as well. I bought the Vulcan over the Rocna on the (perhaps unfounded) basis that I don't want a rollbar that might potentially clog with crap, and SV Panope's tests that show the Rocna not doing very well in a number of sea beds. Are these tests trustworthy? I don't know. I was very tempted by the Viking, but it's very long and wouldn't fit my bow roller without serious modifications.
I have yet to use the anchor, It looks like I will need some minor modifications on the bow roller anyway, to get it to stay firmly in place when sailing. My confidence in my choice has been somewhat dented by SV Panope's recent tests in soupy mud. But the anchor has been bought, and it's unlikely to be worse than the smaller Delta copy it replaced. I'll evaluate it over the coming season and see where I stand.
To get back to the topic: 25KG Rocna vs 20kg Vulcan: Why not 25KG Vulcan, why are we comparing anchors of different sizes? What's the recommended anchor size for the boat, according to Rocna?
cheers Jonathan Thank you for your very comprehensive reply. Maybe I should change the thread to Viking or vulcan? (yes viking is up there on my list too, I already have the mud collecting Rocna hence its existence in the question). watching SV Panope and as a rule he doesnt fit a swivel, what's your thoughts not fitting a swivel? Chris
Knox experience.
Knox, 18kg, boat 41”, 22klbs displacement. It replaced a 60lb CQR. Works well, fast setting, has held in 45kt gusts, mud seabed. I have used it on sand seabeds and in Kelp with good holding based on reversing in. It does have a very strong shank and is a quality build, good galvanising. Will lift up dobs of mud but they fall off with dunking or just motoring ahead with the anchor just below surface, my bow shape allows this. Happy with my choice, better holding, lighter to handle on surface thank CQR.
Worth considering in my view. Feel free to ignore, no need to comment if you have decided on the one of the two stated in your OP.
Rocna was a choice but at the time there was bad press about the shank strength. Today their shanks still look puny compared to the Knox.
I'll try to make this as exciting as possible - to reward your investment in time on the poorly documented discussions on anchor choice.
If you have doubts, which you actually express, on the veracity of results by Steve Godwin (aka Panope) on Rocna then I'd question why you don't express concern on the reality of his work on other anchors - unless you think he has a vendetta against Rocna.![]()
I destructively tested one of the new Rocna shanks. Its strength was not quite up to Bisalloy standard but only a little less. Getting on for twice that of a Delta, same thickness per weight, and they are not often bent.The quality of the Knox build looks exceptionally good and robust. The welds are massive. There is a possibility it is over engineered (not a characteristic that should be ignored). People complain that Danforth and Fortress catch items in the toe between the 2 split flukes. An individual whose integrity I respect tested a Knox and had his chain caught in the split toe - suggestions were made that the toe might be closed - but this has not eventuated. I have tested a Knox and find it a good anchor and have not had our chain caught in the toe - but it is quite possible. You could seal the gap with an inter screw
Rocna did have a period when the steel used in the shanks was below specification - and shanks bent. The issue was resolved - though it was never declared what the quality was of the 'remedial' (replacement) steel - except that it was adequate. Prior to the lapse in quality control and after the problem was identified and shank steel quality returned to 'adequate' I have never heard of a shank bending - and there are a lot of Rocna anchors out there.
I am not a fan of Rocna, someone let their eye off the ball - which I find difficult to forgive (but that's me, but I try to be objective - all anchors are a compromise - its a good anchor). But the issue was resolved and I intensely dislike the trolling that is still evident even though the anchors were replaced free of charge, the error identified and rectified and there have been no issues since.
What possessed the testing in the first place of an anchor with a bent shank - needs questioning.
Jonathan
