kunyang
We're looking at a yacht to buy and it has a 24v system on board. Is this a problem. Is it easy to get Raymarine or BG etc instruments, etc. What are the thoughts / experiences.
Thanks Dave
Thanks Dave
Yes I would think it a definite plus having a 24v system. Starter winches thrusters inverters heaters etc all use so much power that 24v is far better. Less volt drop in wiring due to current being only half for the same power. But also any small volt drop is less part of the starting 24v so less significant again.
You can get voltage converters for 24 to 13.75 volts if you really need 12v nominal for any gear.
Does the boat have a dual 24v system if so this gives you redundancy for engine starting? If not an ideal system might have the 24v for the engine which via a VSR feeds a 24 to 13.65 v converter to a 12v battery for domestic services. Hence no concern about flattening the 24v battery when anchored. An even better system would have 2x 12v batteries in parallel for domestic. An arrangement of jumper leads or switches could then be used to put these in series for 24v engine jump start if and when engine batteries get old. good luck with the purchase olewill
