Boathook
I am not so sure.
As far as i can tell it has a 2 pole RCD and two single pole mcbs
If I understand ISO 13297 correctly you still need a 2 pole circuit breaker on the incoming supply.
The whole unit is described as a RCBO because it does combine the function of RCD and mcb into one box but it does not have two pole overload protection.
The RCBO's I have used at home are only single pole. If double pole are made I would use them on board if I was doing a rewire.
