Goldie
It looks like it comes with a grinding disc which I guess would be 6mm thick.
It will cut even easier if you replace that with a cutting disc which will probably be more like 1mm thick. You'll not need to use any pressure then.
+1 I have 1mm thick discs for cutting stainless steel. Something like http://www.axminster.co.uk/bosch-ultra-thin-metal-cutting-discs-ax31571
