mjf
FWIW - several years ago now I had a white smoke moment after a shortish 30/40 min run and last mile at WOT then puff white smoke aka Red Arrows.The engine has done only 400 hours and has full service history, we bought the boat new in 2007. I've attached a photo fo the faulty piston which appears to have melted. Volvo say the only engine fault found was 'low fuel delivery' after an injector test, they had expected over delivery so they want us to pay to test the fuel. I'm no expert, but if the fuel was at fault why would only 1 of the 6 pistons on that engine have any heat damage? The other engine seems fine as does the generator. Does anyone have any experience or views on what could have caused this? The engine is basically a write off because some of the piston rings from number one have ended up in the other cylinders and apparently damaged the Turbo along with everything else.
Thanks very much and any help appreciated!
Shut down engine but no mech. noise just smoke and no power. Engine would not restart but heaps of smoke when I attempted to do so.
Long story short = Cause was a bolt that was hollowed in manufacture that had allowed the injector pump to turn a little and thus put out the timing. It was only discovered as this bolt (final bolt to be tighted) was turned up on re-assembly.
I always wondered what would have happened if I had kept running that engine???
Maybe way off the point but worth checking that side of the house.
I still have the bolt
Extremely sorry to hear of the failure / inconvenience and hassle you must be going through.
