neil_s
I think it's a fuel problem. The mag is a simple flywheel job with nothing complicated to go wrong. The Vire 6 I had used a Tillotson diaphragm carburettor - is it a similar model on the 12? If so, the diaphragm might have developed a small hole and need replacement. This was a common fault with my Vire 6. Indeed - it might be worth checking that the crankcase pressure pipe is OK.
Best of luck with your engine!
Neil
Neil
