differentroads
I don't claim extensive experience (see above) but on my boat at least, foresail induced rolling wasn't a problem with both sails in their grooves. I could adjust the sheets to spill wind (loosen them so the sails went forward of the stay in a v. You need long sheets for this!). And reefing them to suit wind and waves while maintaining speed was a doddle. Offbeat is relatively heavy and conservatively rigged for her size (10.3m with a sail area over displacement of 12.5) which probably helps. The sails are high-footed Yankees, which will reduce downward pressure compared to a low cut genoa (uplift is better than downward pressure.)Our boat came with a twin groove furler and three genoas. I am hoping to use two of them as a downwind rig when we set off long distance cruising next year.
The rolling/oscillating comments worry me a bit. How much of a gap do you need between the two sails to reduce this? The hole in the top of a parachute is pretty small... so could a small half-circle be cut out of each luff (leaving the bolt rope intact obviously). I would be unlikely to use these two old genoas for serious upwind work so no problem modifying them.
Maybe it would be easier to use hanked sails with slugs to fit the furler... but I already own the genoas...
My arrangement is with two poles on the mast which is said to provide the leverage to induce rolling. If this develops into a problem for me I'll experiment with a Twistle rig. I'll try the Twistle knot first and, if I need, get the ironmongery made up. But, so far, I'm happy with my low cost set up.
