powerskipper
poor Tom, thats scarey. and noisy. , Sure I did see you did wave but was ignored, hhuurrmp
poor Tom, thats scarey. and noisy. , Sure I did see you did wave but was ignored, hhuurrmp![]()
And who the hell allows THREE 16A plugs off a single 16A socket ? (Pic#1) That's bordering on criminal negligence.
I can only see too. Besides, if the breaker's OK, meh. I bought a couple of 4-way 13A extension at IKEA last week.
That's mad ! Tiny, tiny wedges, which look as if they are made of pine or similar squishy softwood. One goes and the others follow suit. So needlessly sad for the owners.
The feet end of the shores (Pic#2) look as if they are not chocked or angled to provide max grip on the tarmac, and the lathes that "tie" the structure together are ridiculously small in section.
Softwood wedges should always be used on shores as they give a greater bearing surface and prevent hardspots. This looks very much like a case of an owner breaking yard rules and moving a shore.
1That's mad ! Tiny, tiny wedges, which look as if they are made of pine or similar squishy softwood. One goes and the others follow suit. So needlessly sad for the owners.
The shores are battened together, so quite hard to remove one, certainly an exercise not for the faint hearted....a bit like removing the last jenga piece
1
We used to commonly use shores on boats ashore and we only had one boat fall over in the hurricane of 87 and that was because a cover had come loose and acted like a sail. On two other seperate occasions we had boats go over because owners had removed shores for antifouling.
1Softwood wedges should always be used on shores as they give a greater bearing surface and prevent hardspots. This looks very much like a case of an owner breaking yard rules and moving a shore.
You can see other boats also propped up with no wedges on the tarmac. Anyway, they can only give a greater bearing surface if they are big, which they are not. As for the owners moving shores, I thought a pro cleaning company was involved.
1
To the best of my knowledge I believe the cleaning company were on deck at the time the boat fell over
just fortunate nobody was injured.. or worse. I can't imagine the horror of standing on a boat when its on the hard and it starting to move...
