sailingjupiter
Active Member
As the title says really. I replaced all the fuel lines recently and so had to bleed them. The bleed screw on the engine fuel filter (secondary?) opened OK but when I re tighten it, it just keeps going. There is a tight spot then it goes loose. If I keep turning, the process is repeated. I have stopped at the tight spot assuming that this is the best point for keeping any air out.
Have got the engine going (eventually) by bleeding all the other bleed points as well. Has happily ran for an hour or so. When I re start within the day it springs to life straight away. But if I leave it overnight it takes very much turning over for it to fire. Mostly it doesn't sound like it is trying. Now this may not be related as when its cold this engine has always been like this. When its warm outside it is much better but not perfect!
Partly the reason for replacing the fuel lines was to try to stop this starting problem as I assumed the old lines were letting air in. Interestingly today I thought I would bleed the problem bleed point before trying to start. Fuel started coming straight away when I operated the priming leaver, so is the screw tight enough?
So to sum up. Is the bleed screw not tightening a problem? Should it tighten up tight as you would expect? Do I need to buy a new housing for the fuel filter (it also has the bleed screw on it). Can anything else be done? Also what is my starting problem if it isn't the air getting in? I have read many 1GM10 threads on poor cold start but none appear to answer my problem. This year I have replaced battery cables with some very big ones, new battery with high cranking amps, replaced fuel lines and had the injector checked and was told it was good and didn't require a service.
Any suggestions much appreciated.
