langstonelayabout
My 1GM10 engine is running very hot. It does run properly: no black soot or steam.
I’ve checked the entire cooling water system (from the inlet seacock, the tubing through and including the water pump, into the engine and into the thermostat) and finally to the exhaust elbow which, (like the cylinder head) is nearly new.
There are no restrictions in any of the tubing but there also doesn’t seem to be that much water coming out of the exhaust…
Because of the excessive heat it prompts a couple of questions…
1 The pump impeller is new. If I’ve installed it with the lobes pointing the wrong way will that reduce the quantity of water that will be pumped through the engine?
2 The thermostat. I’ve not had the chance to check it works correctly. The rest of the boat is 25 years old. Should I change it out of course as its failure could cause this type of problem?
Could there be any other concerns causing this problem? I restarted the engine a couple of minutes after stopping it yesterday and the water temperature alarm sounded for nearly a minute before silencing itself (No, I hadn’t closed the seacock).
Your thoughts please?
