co256
Page 122
Not in the edition I have.
If you move to a marina and have corrosion issues and zincs not lasting long, it is either the marina's wiring or the ac on another boat. Not the dc on yours. Through hulls in my opinion should not be bonded.
Nigel Calder must have changed his mind because that certainly is not in my copy.
So what difference does it make, knowing that electricity can go seven times around the world in a second? (one of the few things I know about it)
Bog standard Hitaichi alternator would not be an easy job to double insulate, to forget the starter and leave earth return, still has to be supplied on the negative to the battery. I have never seen a starter that fits your engine that is fully insulated, but thats not to say there isnt, if there is, I`v been in the wrong industry for years. IMHO the insulated system whist being the ultimate, for this engine is a complete waste of time also taking as gospel all that you read can take you down the wrong route.
Other posters have pointed out the main reasons for not going down the the route suggested.But I wish you well in your quest for perfection ,
I understand that the alternator isn't insulated and should be for that perfection that you talk so fondly of, but surely a heavy copper cable from the alternator case to a "common ground point" would provide an easy path for earth leakage and therefore remove that same earth leakage from the engine block???
Thanks again!
On any boat with an AC system there has to be an earthing connection for safety reasons and that is logically the engine block. This would apply to most boats. I know of no other way to safely do it. And you say you have no corrosion issues. If it isn't broken why try to fix it?
two ways to attach the AC system. The way you describe above above and a disconected earth system with a low value safety switch. Nigal Calder wrote a long article in Proffesional Boat Builder a few years back. It discussed the pros and cons of both systems.
Don't bet on it!I think that concludes this thread
