1983 Bukh 20 hp. Indirect injection
vyv_cox
16 May 2001
France, sailing Aegean Sea.
coxeng.co.uk
Seems most unlikely, otherwise (a) why would Bukh fit such a device in the first place, and (b) why have I never heard of anyone suffering such an outcome, given the number of Bukhs there have been out there for many decades?
I spent years using the decompressor to stop my old magneto ignition pushrod 500cc single AJS without ill effect.
Just an attempt to reason why Bukh tell us not to do it. The decompression facility is to assist turning the engine over by hand. What is your reason for the instruction not to do it?
James_Calvert
6 Oct 2001
Mine (1985 and one of the last batch of 20s) doesn't have a thermostart. It does take a little while to fire up when very cold. I think that's normal...
James_Calvert
6 Oct 2001
Would it be prudent to carry a spare exhaust elbow?
The difficult bit in replacing it is in unscrewing the old one off the exhaust flange. Big pipewrenches, a bench vice and heat maybe needed. Ideally you'd have a spare made up complete with a spare flange and gasket, then it's an easy DIY job. Alternatively get a spare, fit it at leisure, and you're good for another 5 years.
LittleSister
12 Nov 2007
I wasn't aware Bukh tell us not to do it. Where is that? (I have checked and can find no such advice in either the current DV36 manual, nor an ancient DV10 manual I have.)
My reason for querying the aversion to stopping an engine with the decompressor is that I thought based on my experience, albeit indirect, is that it is unlikely to be a problem, and thought that might be of interest to the forum as a potentially less hazardous means of means of stopping the engine if the solenoid stop fails than trying to block the air inlet. It is what I would do in that situation.
Seumask suggested, and had used, the decompressor to stop. Vic said he thought it was 'generally' not recommended, but didn't know why. You made a tentative suggestion why it might be. I was just throwing my experience into the pot.
vyv_cox
16 May 2001
coxeng.co.uk
I cannot find the Bukh advice at present but I do recall reading it. Googling the topic of stopping diesel engines using the decompression lever finds lots of hits, all saying never do it. Here is one of them:
Module 2, Engines
◄ Previous activityNext activity ►
You are here
CP Fitters Homepage / ► Engines / ► Resources / ► How a Valve Looses Heat
How a valve looses its heatHeat is transferred in 3 ways:
Conduction
Convection
Radiation
In a running engine, valves get very hot, and unless we remove this excess heat, the valve will quickly overheat and burn. The valve land and valve face will be damaged, and the gas-tight seal between the land and the valve seat will be ruined.
In a running engine, a valve looses about 5% of its heat through radiation, and out the valve port.
The valve also looses about 25% of its heat through conduction from the valve stem, through the valve guide, and on to the cooling jacket. The reason this figure is not higher is that the valve stem must be a sliding fit in the valve guide, so contact between them is not at so high.
The bulk of heat (75%) is lost through conduction between the valve land and the valve seat. Unlike contact between the stem and the guide, here, contact is very good, as the valve is held in place by a strong valve spring.
If, for any reason, there is not good contact between the valve face and the valve seat, the valve will tend to overheat, and can be burned and damaged, thus destroying the gas-tight seal.
This is why it is so important never to use a decompression lever to stop a diesel engine-it causes the valves to be burned.
Last modified: Thursday, 29 January 2009, 12:22 PM
You are currently using guest access (Login)
chewi
8 Oct 2007
Poole
Module 2, Engines
You are here
Conduction
Convection
Radiation
I'm confused by that explanation.
What difference would it make stopping by the solenoid? Wouldn't the valves still stop in an arbitrary position just as they would by decompression? They don't burn out that way.
LittleSister
12 Nov 2007
Thanks for that, Vyv. I remain sceptical, though.
Once you lift the valve with the decompressor, there's no further compression, and there's no further firing. So, from where would the heat come to 'cause the valves to be burned'?
We are, in any case, talking about an emergency stop for the engine. Doing this once, or even a few times, ain't gonna burn out the valves.
Champagne Murphy
5 Jun 2011
Suffolk
If we took the logic to its full limit we would all carry spare alternators, HP pumps, exhaust tubing, gasket sets, water pumps etc etc. Given the cost of Bukh parts I don’t think I could afford it, even if I had the space!
As I said, I’ve only replaced it once in 7-8 years, a spare might have rotted away in a damp bilge by now!
VicS
13 Jul 2002
Me too. Doesn't seem logical.
My thoughts are that when used as a starting aid you operate the decompressor to slightly open stationary valves or at least to prevent slow moving valves from closing completely during cranking.
however if you use the decompressors to stop a running engine they come ito contact with rapidly moving valves and in the few moments it takes for the engine to come to rest they will have been hammered a number of times by the closing valves.
rotrax
17 Dec 2010
South Oxon and Littlehampton.
Last year I stripped and rebuilt the Bukh DV20 fitted to our Hartley 32 in Wellington, NZ. It had not had a working stop solenoid in six years to my knowlege, and by the look of the innards of the old one, it had burned our long before that. The decompressors had been used to stop the engine since it failed.
The tops of the rocker arms and matching surface where the decomp lever acts were badly worn. As only the decomp lever acts on the rockers there, perhaps that is why Bukh dont reccomend it.
I managed, with a bit of ingenuity and common sense, to adapt the bit of stop solenoid to be cable operated.
Works a treat and cost just time and odd bits of scrap.
LittleSister
12 Nov 2007
I conclude from that there is no problem in using the decompressor to 'emergency stop' a Bukh, which is what we were discussing.
It is strictly true that Bukh 'don't recommend' using the decompressor to stop the engine: but only because they don't mention the decompressor at all in relation to stopping. (The manual just says turn the key to stop!) Nobody has been able to point to anything written by Bukh recommending the decompressor isn't used to stop the engine.
stevie69p
7 Nov 2016
Glasgow
Pretty certain I read in some Bukh literature that it is acceptable to use the decompressors in an emergency to stop the engine, but not to do it on a regular basis.
When operated, they act directly on the top of the rockers to hold the valves open, which I would assume then leads to the pushrods clattering up and down with no rocker surface to bear on to.
VicS
13 Jul 2002
FWIW
Yanmar say it is because fuel accumulating in the cylinders could make restarting difficult !
jwilson
22 Jul 2006
I had a boat with a single-cylinder volvo 7 hp that was fitted with separate throttle and gear levers. Fully back on the throttle stopped the engine. As it was far too easy to accidentally stop instead of just going to tickover the previous owner had adjusted the throttle cable/lever so it would not actually stop the engine. So always decompressed to stop. He'd been doing it for years and I did too for many years.
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
I always carry a spare engine
