sgr143
When I suggested that in post #39 I was told I was talking rubbish.![]()
Me again - the one whose anecdote about a burnt-out solenoid and stopping the engine by blocking the air intake kicked off this discussion.
The "emergency stop "procedure I used was the recommended one on the RYA diesel engine course I went on.
Of the various explanations that everyone's chewed over, I think the one about not creating very large clearances in the valve train when the engine is at operating revs is probably the most tenable. My black museum of knackered Triumph engine parts (1961 6T) has a fine set of pushrods with cracked and splayed ends caused by my letting the valve clearances go way out; the engine still ran but the innards looked rather a mess when I checked! So I think you'd get away with stopping the engine using the decompressors for quite a while, but in the long term it might risk some damage to the valve train.
Dylan - don't be put off by Bukhs - they are reassuringly solid and simple engines. But it sounds like the boat has enough other stuff that needs attention as to not be worth your while?
Steve
