sailorman
air conditioning /heating units,washing machines,dishwashers, large freezers ??As a matter of interest, can anyone tell me what kinds of things people have on their boats that would require 32A, which is nearly 8KW??
It does, however, have a lot to do with the current potentially available to flow through the cable.
it would still be protected by an RCD in the pillar
An RCD has nothing to do with protection against high current.
It is a device to detect and trip in the event small ( usually 30mA ) earth leakage currents as a means of preventing electrocution. The max current ratting of an RCD is merely the maximum current it is rated to carry. You need a fuse or an mcb to protect against high current flow arising from short circuits or simply overload.
The fuse or circuit breaker on 32 amps supply socket should trip if 32 amps is exceeded. However if all the down stream wiring and other components cannot safely handle 32 amps they are at some risk.
Unless the marina is breaking all regs. it doesn't matter. The supply point in the marina should have MCBs for each socket and an RCD protecting the lot, usually 2 or 4 sockets. Any short or imbalance such as leakage to ground on the shore lead or boat would isolate the shore lead instantly.
ADD - Don't forget the household ring main has 32A breakers and no-one worries about plugging a 0.5mm cable in.
It should be protected by the correct size of fuse in the plug. ........... If not they should worry.
In a situation where appliances are subject to PAT they should fail if they do not have the incorrect fuse fitted in the plug.
Where they have radial sockets protected by an MCB, in two different capacities.The whole of continental Europe manages fine.
And with 2 pin plugs with a 50/50 chance of reversed polarity.
re read#12, what is supplied from the marina pillar has nothing to do with thew price of eggs
I had a 16A socket connected to a trio of crocodile clips, for clipping into the nearest lamp-post. I also had a key, but they were usually open and in use.... Amazing what you can find in the quieter back waters of Greece...
