12v Tv & wiring
ozzyb
2 Dec 2001
Home Herts UK, Boat in Morbihan S. Brittany
I recently picked up a 19" LED TV/DVD for boat which turned out to be 12v with transformer. I want to rig up the wiring to also come off the 12v panel if necessary, is there any reason I shouldn't.
I have 0.75mm multi strand external cable, distance is 1m, TV unit is 12v 3.9A 47w
Any advice gratefully received
Only that your "12v" wiring will sometimes provide 14.5v and sometimes 11ish. The telly may or may not cope with this. If the telly wasn't too expensive I might be inclined to try it, but it's your risk.
Done that and those figures seem similar to what I have on my TV/DVD (Technika). I just made up a two 12v plugs (one end to the TV) with a fuse and connected to my standard interior cig socket (12v Socket). I don't use it when the engine is running, however I did once without realising and the TV wasn't affected by 14v (ish).
This was also discussed some time ago on the Motorboat forum relating to cheap 12v TV from tesco at the time and the wiring.
I got the adapter for the TV from Maplins (if I remember correctly), but available else where like ebay. Just make sure you get the polarity right at the TV end!!
I did exactly that with a cheap LCD tv I picked up on gumtree. Works fine on 12v wired direct from switch panel. Also used it with engine running so handles higher voltage fine. I have a temporary aerial that I mount on the pushpit and Have a coax run from the tv to a connector in the cockpit locker.
I strongly suspect that most kit will include a standard voltage-regulator chip on its power input and so will be absolutely fine with charging voltages on a boat. You just have to be aware that there's always a chance you got the one whose designer saved tuppence on the parts list by missing this out.
I might be tempted to open the thing up to see if it had such a chip; they have a fairly distinctive shape.
Why? It's normally run off a regulated supply.
I realise that several others have them working fine, but the 240v transformer gets AC current. Is it a rectifier too? If not, will the 12v system on the tv be ok with the dc currnet from the battery?
Just a thought
One problem you might get when connecting the TV (or anything else for that matter) directly to the boat's 12v supply is that it's generally very noisy with pumps coming on and off and lights being turned on and off etc. Some electronic equipment (my satellite phone for one) doesn't like the spikes and sudden (minor) voltage changes that you get on a boat's electrics.
