billgray
We bought a 12v 22" Finlux tv+dvd two years ago and are very pleased. A Glomex aerial completed the set-up. Tv and bracket under £200, aerial under £90.
I have room for a TV and at some point i might fit one, but still use the laptop as a media center. I use the same setup at home, laptop connected to the TV via HDMI, TV to home cinema via HDMI. A dual tuner TV dongle means i can record two programs at a time, while watching something already recorded, or a movie. The laptop remains closed and is operated via a wireless keyboard.
So, if i fit a TV on the boat it will be connected to the laptop via HDMI and the laptop will probably be in the chart table (or on it). The cabling is all in place behind the joinery.
Correction to C) I would rather have a Wireless system![]()
we use an Avtex Tv/DVD combo...reception is great with the Avtex aerial which is powered by the tv.....used it in motorhome before fitting to the boat..
My advice to you:
1. Don’t buy a marine/RV 12v TV of any kind. They are all poor compared to normal home ones, and overpriced.
Buy one with any kind of external power supply. The voltage doesn’t matter, so don’t break your head looking for a 12v (or 13.6v) one – because anyway you need to stabilize the voltage through a DC-DC converter. Then just buy a cheap DC-DC converter (DROK ones are sold on Amazon, for example), set it to the required voltage, chop the cord off the AC power supply, wire it up to the DROK, then install the DROK with power from your main panel (from a breaker), and Bob’s your mother’s brother.
2. Don’t buy one with the DVD player combined. Instead of DVDs, rip your movies to a portable hard drive. DVD is low resolution, and is a crappy obsolete technology anyway. I have about 500 movies on board, most of them in HD. It would be impossible to store that number of physical DVDs. For the very occasional case where someone brings a physical DVD and I don’t feel like ripping it to hard drive (easily done on my laptop), I do have a very tiny, multi-region DVD player which I can use. For such rare use it’s not big deal powering it with the inverter.
You play them with your laptop (or permanently installed on board computer, if you have one), using VLC or other media player of your choice. I have a 32" monitor mounted on one bulkhead, with a long HDMI cable run to the nav table. Works a treat.
3. Keep in mind that pretty soon we will be streaming all the movies we watch -- that's the way the world is moving. For that you need to have good data connections, mobile and WIFI. We use a Routerboard Groove wifi device, and a Huawei B593 mobile data router. I did have a freeview TV on board, but it got smashed on one passage this summer. So I've just been streaming whatever TV I need to watch (rare, but sometimes very much needed, like during the Brexit business), and it works a treat. Streaming radio is also nice, and uses very little bandwidth.
Hope that helps. Good luck!
