SimbaDog
This may sound a silly question but I need a bit of advice. I have a 12v push button intermittent switch, ie. only sends current when held in.
I want to use this to turn on & off a small LED light, can I do this using a relay & if so what do I need? I can provide a permanent fused 12v feed to the relay. Changing the switch is not an option as it matches everything else on a panel.
