local343
New Member
Hi there - Looking for some input on my 12v power/charging setup. Unfortunately I do not have a yacht or even a motorboat, but after searching for some time, I hope someone here might be knowledgeable on this subject. Hopefully this will point others in the right direction as well.
2002 Silverado Truck with dual CS144 series 130 amp alternators, one battery bank (2-50Ah YellowTops), and isolated accessory/start battery. Batteries and alternators are currently isolated via Charles StartNow relay (which really only isolates batteries in dis-charge state).
Ultimate goal is to be able to run stereo and accessories down to low voltages and have no problems starting vehicle. I am trying to setup two completely separate circuits (battery bank being charged with future smart externally regulated alternator, and start battery/alternator powering all systems, including 150a max. stereo).
Upon turning off vehicle, the power source would be switched from starting battery/alternator to aux. battery bank. I love the idea of having a 100% fully charged battery bank being charged in float at my disposal every time I turn of my truck.
All the transfer switches/relays I have come across are of the 120v/12v type (marine-shore application). Is there such a thing as a 12v/12v transfer switch? I've thought about higher amperage relays, but this setup would involve dual inputs with common switchable output.
I like the idea of my truck running normally, and want to isolate the voltages that are sometimes associated with charging a depleted battery bank via external regulator from the normal operation of my truck.
Brands I've been researching are Xantrex, Sterling, Balmar, Charles. Can anyone suggest others?
Any and all input-comments welcome. -Nathan
