12v interior lighting.
mickshep
9 Jan 2003
Hartlepool
Hi everyone. Fosca is high and dry with most of the saloon interior consigned to the scrap heap.(It was bloody awfull).
What I am after is a supplier of interior lights, both wall mounted and overhead, pref' a nice traditional design but at a decent price, Also can any one comment on the white LED type flush fitting lights with a brass bezel.,
When I've seen them in the local swindlery they appear gray rather than white, is this just the result of only seeing them in a brightly lit show room?
Once the settee berths are reinstalled they will be beneath the side decks and I am wondering if LEDs set into the deck head would be bright enough to use as reading lights. Thanks in advance, Mike.
<hr width=100% size=1>My Mum say's I'm not a fat b@st@rd, just heavy boned.
bruce
26 May 2004
florida USA
they have a blue white light, not what you might want for gen cabin light, not as bright as reg bulbs. i have several and can read, but would not want to for very long, and light needs to be about 12/18 inches from page for the ones i have. in red, they work very well for night vision.
Talbot
23 Aug 2003
Brighton, UK
In addition to normal stuff available from most chandlers, <A target="_blank" HREF=http://www.classicmarine.co.uk/index.htm>Here </A> are some other alternatives.
Sybarite
7 Dec 2002
France
Just for info. M. Joubert a leading French architect has specified for his own boat only one type of light throughout. This reduces problems with spares.
John.
abraxus
3 Aug 2004
I re did all the lights on my boat not long ago as I didn't like the plastic ones it came with, about 12 lights in all. I got them from Index Marine (www.indexmarine.co.uk) as they seemed quite reasonably priced and had quite a good selection.
kds
21 Nov 2002
Somerset
www.canongrange.co.uk
IMP of Roystan do a wide range of lighting. I flashed out (!) and bought "Frensch" as I liked their LED options and styling. Early days yet - but happy so far.
<A target="_blank" HREF=http://www.canongrange.co.uk>Bed and Breakfast, cathedral Green Wells, Somerset Canon Grange
Gordonmc
19 Sep 2001
Loch Riddon for Summer
I am getting rid of the 12v auto-style bulbs in the cabin lights, but keeping the surrounds. I am using barrel bulbs from Ultraled... each one has four white LED's. I'll be using new bulb-holders, the same as used in my navigation lights.
For reading I use a halogen lamp which I put a second switch onto. This allows it to be used on 240v when on the pontoon or 12v switched to by-pass the built in transformer. LED's are ok for ambient light, but don't do the business for reading or working.
Caravan Superstores ....
and similar have excellent bits and pieces for all domestic stuff ...... water, lights, etc. etc.
You will find 12V lights galore .... etc.
<hr width=100% size=1>Cheers Nigel ..... <A target="_blank" HREF=http://www.geocities.com/solentlifeuk/>http://www.geocities.com/solentlifeuk/</A>
