PaulRainbow
I bought this for my last boat, fitted with a Merc OM636, which had a cable stop. Depending on your stop cable arrangement you could fit this as a stand alone stop, or in parallel with the cable. Just connect the solenoid to a 12v supply, with a momentary switch/button. When you hold the button in the solenoid will pull the stop on the engine, once stopped, release the button the solenoid returns to the run position.
£20 delivered to mainland UK
