niccapotamus
30ft sailing boat - new to us. and I'm rubbish tekically about electrics. but I can join wires together!!
I would like to add about three cigarette lighter sockets to the boat plus a car radio.
at the moment I have inherited from the PO a nicely organised DC switch panel with two banks of fused switches in the usual way taking the feed from the rotary battery isolator switch fed from two batteries (ie usual). The power and negative wires to the exisiting switch panels look quite large - I believe each bank of fused switches has a seperate live and negative feed from the isolator swich (not verified yet however)
The PO then got a couple of crocodile clips direct to the battery and stuck in an unfused cigarette lighter socket right behind the sink!!
I'm trying to do it right.
So I have three questions :
1. power to my new switches - i was going to add switches (ie a new fused switch panel) for the cigarette lighters and the car radio - can I take the power + negative from the main feed to the existing switch units or do I have to run a seperate feed from the rotary swich unit to the new switch panel?
2. I presume that I wire the new cigarette lighters in parallel?
3. am I going about this the right way or is there a simpler way?
Other info:
1. the new switch panel will be minimal - If i can get one, then I will only have two fused swith units
2. the existing wiring loom and switches are very tidy and run the usual small boat electrics - nav lights, cabin lights, VHF and very basic instruments. I will add an ebaspacher in later this year and update the charging circuits as an exercise later this year
3. the cigarette lighters are to run the usual charging stuff - phones, ipad etc, plus a 12v hoover
many many thanks!!!
nick
Other info:
many many thanks!!!
nick
