lw395
Ok,bit late to this game but...
OI you lot, quit harping on about 240V (yeah, I know its easy... lazy buggers). 12V 50Hz is audio!. Think sine wave generator and audio amp.
and another thing... without upping the volts, you cannot make 12Vac from 12Vdc! (its an RMS thing, innit?) That may well be why the lamp barfed at 12Vdc.
So, you need a 12V -> 24V buck converter and the audio gubbins run from that, all done as jdb says "dead bug style"
edit add: use 24V as these buck converters are common vehicle kit.
Nearly right.
12 to 24 would be a boost converter.
Does the 12V ac need to be isolated? does it need to be referenced to the DC 0V?
You can make 12V AC from 12V DC using a bridge audio amplifier. But the output will be two 6V sine waves of opposite phase.
If you need DC isolation, you can put capacitors in series but they will be big.
Or you could use a transformer to isolate.
