jfm
the only proviso I have is whether a diesel generator engine running at a maximum of 2/3 capacity for - say - half the time, and much less than that when the charge to the batteries levels off, is going to be happy and long-lifed. There are issues such bore -glazing especially at light load and extended tickover.
If you can add extra 240v load when the charger moves into float mode, that would give the engine more work to do and make it run well. Perhaps something as simple as a fan heater would do.
I agree the principles Sarabande but 2 things:
1. all this "glazing the bores" is treating gensets like they are Faberge eggs. They're just a box you buy with a cr card and yep sure if the bores are glazed in 6 years then chuck the thing in the bin. But don't compromise your life in the meantime!
2. As mentioned above I just switch the genset off if the batteries are approaching float mode and I have no other 230v loads. There is no need to bother charging them the last 10 % or whatever. sure they will get down to very discharged sooner, but then you flick the genset back on. Your total genset hours are smaller if you do it this way
