PaulRainbow
Getting there now, no doubt more tweaks.
So easy to operate, left switch controls where the boat gets its power from, 1-main bank, 2-emergency bank or both. Right switch controls where the solar goes, same.
Both charger feeds switched as well so at anchor the boat can be run from one bank with solar while the charger/genny does an equalizing cycle on the other. Might have missed something basic though,,,,, where you lot come in![]()
(Edit, just spotted one, feed to windlass is after the domestic breaker..)
Which leaves trickle charging the emergency battery now and again, need to test a buck/boost voltage/current limited device, can't see why it wouldn't be fine though.
And commoning the big fat leads vaguely tidy, piled up on the same stud just always looks a mess.
The trip just after the left switch needs to be rated for the windlass, which makes it useless for protecting the wiring to the busbar etc. My previous suggestion of moving the windlass connection to the main bank should have been to move it to the isolator. That way you can have a lower rated breaker for the domestic wiring.
Edit, must type faster
