superheat6k
Bored and boatless so been looking for a hobby item to keep my hand in. Felt a decent marine generator would fit the bill for the next stinkpot, so been scoring EBAY for something suitable.
I found under and obscure listing a Marine generator water cooled Kohler - looked good and was listed as spares or repairs, with a £90 starting price, so I put in my bid, then just after noticed it was petrol not diesel - hey ho; then it is 120 v 60 hz only - oh sugar !
Duly won the bid, and collected it by courier last week.
The good news is It did start. I have also downloaded the manuals and have gotten to grips with it.
I can also re-connect for 240volt and adjust the governor to suit 50 hz. Value has just doubled.
The not so good news ...
Clearly not run for several years during which time it has been severely neglected.
Carburettor thottle butterfly seized, removed and found full of a jelly like ex-petrol substance. Thoroughly cleaned and freed off the throttle valve flap.
Starter seized lightly - removed and freed off
Put some petrol in and attached a battery and cooling water supply.
Something clicks but no starter
Found the starter control solenoid not working, bypassed now turning over.
Then with the start button depressed away she goes, but won't stay on.
After lots of reading have to check the charge system, as the hold on relay is powered from the generator via a small 12v charge coil.
Field windings of the stator all good; Field winding of the rotor - open circuit
Removed pump to gain access to the brushes - good job pump impeller knackered.
Removed access cover to brushes and slip rings - Oh dear full of oily gunky water that definitely should not be there.
Next step is to clean the slip rings, replace the brushes, plus replace the pump seal and impeller.
If this sorts it I reckon I will have a decent genny for very little cost. Shame its not diesel, but hey ho.
Now next time - READ ADVERT BEFORE HITTING 'ENTER BID' BUTTON !!!
