Twister_Ken
Force 4 is promoting the Scrubbis - "This innovative cleaning tool makes it easy to remove slime & growth from your hull whilst the boat is still in the water. The foam cleaning head is mounted on the end of a cranked, extendable pole & has 2kg of buoyancy, so that it continuously pushes itself up against the hull meaning there is not much effort needed to use it. Simply push & pull it under the hull – just like hoovering! It will give you a faster & more efficient hull &, if used regularly, will even prevent the growth of barnacles."
I've got one and while I'm happy to confirm that it removes slime, it doesn't touch the green fringe that grows along the waterline - the foam is too soft to scrape it off. With Coppercoat on my lugger, there's no other underwater weed to tackle, but if there were I can't see the Scrubbis pulling it off in any quantity. So, good for slimy boats, not good for weedy ones.
