MapisM
Many thanks. Any idea on timing?
Yes, but NMEA is very much a second class citizen in their ecosystem. Not all NMEA sentences make it, and not all are used.Raymarine plotters accept NMEA inputs, presumably they also put the incoming data out onto the seatalk bus?
I have just had a response from NASA Marine, saying that they will have a modified version of their EM transducer that will output a pulse output suitable for use with the ST60.
I'd imagine the log is a pretty basic message, but I can't check as I can't get to the boat.Yes, but NMEA is very much a second class citizen in their ecosystem. Not all NMEA sentences make it, and not all are used.
But, sure enough I had my boat doing a good 23.4 knots whilst tied to the pontoon according to both the plotter and the ST60+.
So, having finally got to the boat (only minor damage), I tried this out.
My boat has an ST60+ speed wired through Seatalk to an E7D plotter and an AIS650 transponder connected to the plotter via NMEA 0183 (the fast version)
Because of the gubbins it's easier for me to get to a spare NMEA input on the AIS, so I wired up the PC to that, and set it to churn out speed messages. The plotter needs to be set to use NMEA as its data source for speed, and the ST60+ needs the paddlewheel disconnecting.
Yes, VHW.Just to confirm, you were sending speed through water messages?
And did the ST60 distance/trip increment. And if you have an ST60 wind was it showing true wind based on the speed you were sending?
Congrats.Update!
I have, after a bit if a struggle with the wiring, got the NASA transducer working with the ST60. It reacts to speed changes much quicker than the SOG from the GPS, and seems to be reasonably accurate. I need to calibrate it properly!
Pulse generating.Congrats.
Is that using NMEA or did you get hold of a pulse generating version?
Pulse generating.
Update!
Does it have a part number?
It was a modified unit from NASA that emits a pulse output via a modified electronic interface unit. I only have the part number EML-2, but I think that's the original NMEA emitting unit; the unit I have has all the hallmarks of being a prototype, including incorrect documentation that required several emails to clarify! However, I'm sure that enquiries to NASA will bear fruit.Was that using a "modified unit from NASA which generates a pulse output, or did you use n alternative method ? (and oif so what ?).. Really interested in this but my electronics knowledge isn't what you might call advanced . Many thanks ......
No; I had to add a resistor in the relevant connections to the ST60 to give it a fake temperature.Thanks .. might be in the market for that but in no hurry .... I have a feeling my paddle wheel sensor does water temperature too though ... does the NASA unit do temp?
