Mini oil leak on KAD 44
simonfraser
13 Mar 2004
See pic, guess not even a teaspoon per hour, any idea which bit might be seeping
been there for at least a year, not getting worse, yetFE07E76E-B92F-4F08-A2C6-C2F588C7B8F2.jpeg
Mr Googler
11 Apr 2008
Sorry Simon….how can anyone possibly give you an answer!
Get everything clean, get a torch out and have a good look about for the oil tracks
Sneds
26 Feb 2007
Bristol
Similar thing, an oil breather pipe was the culprit, it was pointing downwards rather than upwards
Sorry for being so technical!
simonfraser
13 Mar 2004
Tnx oil cooler, I’ll have a look at the diagrams and get the torch out
rocker off 3 months ago for tappets, bilge has never been this clean in my ownership (pink stuff excellent) blue roll (used for leak detection) now sliding about and not sticking to the floor any more 🙂 (steering pin was leaking, seal replaced, there is now proper resistance when greasing)
too many brackets !
DrSpock
31 Aug 2016
Front seal is quite common and can usually be replaced in the boat depending on access.
oldgit
6 Nov 2001
Medway
+1
less trouble/cheaper to fix than some apparently less complicated problems .
Cost around £12 from ebay or £40.00 from VP.
simonfraser
13 Mar 2004
wiped the bottom nuts on the oil pan, 3 had a drip hanging from them
ran the kad for another hour, oil drip not returned yet, gonna call that a micro drip now :)
thats what you get with a clean bilge and a bilge cam .....
