FairweatherDave
Apologies for this seemingly basic question but my heads going round and round with it.
I want to degrease my gelcoat (which was painted) prior to painting again. I like the idea of a "powdered household scouring cleanser" (see below) but in most supermarkets I think Vim is no longer available. So what product should I use as I want to avoid premium priced marine products if I can?
I knicked this advice from the Awlgrip website. ......
"SURFACE CLEANING
A clean, dry surface is essential to the success of any coatings application. Remember– Clean before sanding. Sanding often melts grease, wax
and oils into the surface making it impossible to obtain a clean surface.
Detergent Scrubbing
Many applicators scrub the surface they are going to paint with powdered household scouring cleanser and a Scotch-Brite Pad before any other prep work is performed. This is an excellent practice as careful observation of the rinse water will tell you when you have a clean surface. Breaks, holes or beading of the rinse water indicates areas which need additional attention."
"SURFACE CLEANING
Detergent Scrubbing
