Who owns (and still uses) the most ancient bit of marine electronics.
Snowgoose-1
2 Jun 2015
Seafarer 700 echo sounder and Seacourse tiller pilot. Not in use quite yet, but soon.
You could, until fairly recently still buy the Stingray sounder from NASA Marine. Their website say they are no longer being made because the right parts are becoming scarce.
I don't wish to swank, but I have the one that also has a digital read out as well as the whirligig . Also stand alone if required with AA batteries .
wombat88
1 Oct 2014
Seafarer depth sounder anyone? Or better still a VDO speedo/log driven by a small prop and speedometer cable. Admittedly I took this out...
DownWest
25 Dec 2007
S.W. France
The 700 has a digital readout (bit cloudy) and takes a 9v battery. On the shelf, I also have the Seafarer log unit with the solid state sensor, but that is staying there.
Best bit of old kit is the central processing unit that integrates wind speed and direction, depth, course to steer, speed and autopilot, but that is begining to get glitches, dates from '47 :cool:
Rappey
13 Dec 2019
Seafarer voyager echo sounder,(digital)around 35yrs old, on its 2nd transducer but a great echo sounder.
Seafarer voyager wind instrument. The part up the mast reliably spun and rotated for 33 years without any maintenance or repairs but finally lost the wind direction readout. Took it to be repaired, but it is not repairable :(
Buck Turgidson
10 Apr 2012
Zürich
Prosser Tideclock.
I'm sure this was state of the art at some point in the past. Its current function is to hide the screw holes for it's own mounting bracket in the otherwise lovely GRP. It still works but I've never used it in anger.
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
Prosser Tideclock.
I've got one of those too. I usually get tide curves from the BBC website but use this device when there's no GSM signal. It's quicker than booting up the chart plotter if it's not on.
Frank Holden
23 Nov 2009
Cruising in the Golfo Corcovado
Did someone mention Lucas - Prince of Darkness?
I still have the original 1986 Lucas sternlight on my boat with the original incandescent bulb. It's outlived more than a few Aquasignal tris and bi's.
Some young pup suggested I should change it for a fancy new LED jobby ( that's Glaswegian).
That would be akin to turning off the Centennial light
Centennial Light - Wikipedia
oilybilge
3 Nov 2017
It's hardly an antique, but our boat came with this very nice Stowe trailing log.
