The tide doesn't rise and fall!
dombuckley
11 Apr 2005
Norfolk
Good, but ignores the fact that the earth also bulges (to a lesser extent) under the influence of moon and sun (called 'earth tides').
sarabande
6 May 2005
And the earth is permanently flattened at the poles, being about 15 miles wider diameter at the equator. It's an blate spheroid.
I don't buy the video's explanation of the earth rotating inside the outer coating of water. The speed of earth's rotation at the equator is1660 km/h, which would make for interesting tidal streams and a LOT of erosion if the outer water envelope stood still.
Ocean tides are a lot more interesting than that. Arctic Pilot is your man with the explanations about intertidal, semi-diurnal, and storm surges.
RunAgroundHard
20 Aug 2022
The tide does flow in and out. The deformation in the water level due to tidal forces exists of course, but the surface is not homogeneous and forces the water to flow around and through restrictions. There is also a delay in the height of tide in relation to the tidal force, hence the water flows to the strongest tidal force.
The can be seen in many places around the world, as well as obvious differences in sea water level over small areas. External forces such as air pressure and gales can delay the movement of water due to tide force.
Also each molecule of water that has to bulge due to tidal force must move to that position, hence it flows.
Slowboat35
4 Apr 2020
Talk about stuck with language - the man's hoist on his own petard, apart from talking utter bullshine.
If the earth rotated within the 'bulge' as described and illustrated then currents would flow at around 1000mph at the equator...
srm
16 May 2004
Azores, Terceira.
He might be correct, on a planet where the moon, planet, and sun remain fixed in the same relative positions and a uniform depth to the ocean with no land masses. Our earth sun and moon have a much more dynamic relationship making for a much more interesting marine environment.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
I don't intend to watch the video (life's too short, at 80 anyway). But if there are any changes in depth the water cannot mysteriously levitate so the length of the water column, and hence its (incompressible) volume, must change. So there has to be lateral flow, to or from adjacent water columns, to accommodate that...
LittleSister
12 Nov 2007
He doesn't say the water is stationary, he says the bulges in the water are stationary.
. . . Ocean tides are a lot more interesting than that. . . .
They are indeed, and I am sure that he would agree.
(He is famous as someone who delights in the myriad 'interesting' things about the world and universe, and an expert at making science (and astronomy in particular) interesting and accessible to the public.)
He is by no means denying all the interesting and complicating factors in tides, just adding further interest and fresh perspective on its fundamentals.
I am sure that internationally famous astrophysicist and science educator would be pleased to be put right by you! ;)
Neil deGrasse Tyson - Wikipedia
oldmanofthehills
13 Aug 2010
Bristol / Cornwall
Of course, but he is not suggesting there isnt, though his explanation is a bit overly dramatically simplified on that point. He is merely pointing out that the bulge keeps trying to align with the moon, and also the sun as its their gravitational influence that raises the bulge thus the bulge is stationary relative to the moon. Indeed we must be fractional lighter if the moon is overhead - just think of us as sentient water, or at least semi sentient.
Of course the whole caboodle is whizzing through space and rotating with the galaxy, so there may be semantics in the term stationary
srm
16 May 2004
Azores, Terceira.
But obviously not an oceanographer, hydrograhic surveyor or marine navigator.
He is using the simple tidal theory for a water world, where bulges would remain stationary.
On our world the tidal waves rotate around amphidromic points, or tidal nodes, with zero range. There are three in the North Sea. Ocean basins have one or more, influenced by surrounding land masses and depths.
Simplified world map:
Amphidromic point - Wikipedia
Or if you want more text info this is a starting point for a potentially complicated subject:
LittleSister
12 Nov 2007
But he's not talking about the fine detail such as tidal waves in the North Sea, but the overall vertical movement which generates, and provides a context for, such local phenomena.
The two - bulges at earth scale and local scale amphidromic points - are not incompatible, they are interrelated.
