SYRINGES for WEST SYTEMS EPOXY
STATUE
5 May 2010
S. Dorset
50 mil 'ish syringes to fit through West Systems Epoxy tins. Try as I might, I can't get a straight answer from them.
No , I don't want or need there pumps.
onesea
28 Oct 2011
Solent based..
The problem with medical syringes is the epoxy can be to thick for the holes in the end of the syringe. Certainly true for polyester resin.
iamtjc
21 Sep 2018
I have found a small syringe great for West systems hardener. The epoxy is another matter. It seems to swell the 'rubber' seal and make the syringe hard or impossible to use. For small quantities I have found the syringes you get with Calpol (kids paracetamol liquid) that have no rubber seal work well. I haven't found a good solution for larger amounts.
Also clearly you can't get those small syringes into the cans so I decant a bit from the cans into a couple of well labelled old spice jars. A third spice jar filled with colloidal silica and you have yourself a small epoxy kit for minor jobs.
oilybilge
3 Nov 2017
Yes the pumps are crap aren't they. Second pair packed up on me this spring. Since then I've been using a ruler to mark the levels on the outside of the mixing container, and for very unimportant work like the filling of dings I do it by eye.
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
There are several things about pumps I don't like:
  1. Slow for large volumes.
  2. Difficult if the epoxy is cold ... which may be intentional for large batches to slow the exotherm.
  3. If you have not used them in the last few hours there will be air bubbles. How much was that measure?
  4. You can't measure less than a full stroke. And because of "3", not less than several strokes. You can weigh tiny amounts.
  5. You have to have the correct ratio pump for each product pair. Not so with a scale.
  6. The mess. You either have to remove them after use or leave them in the can, which means the can is not sealed.
You can also weigh additives, though I generally just go by eye, since it is often temperature dependent.
And anyone that can't do 1:1, 2:1, and 5:1 math in their head shouldn't be doing epoxy.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
I use to use pumps years ago. Very good if regularly used but soon go sticky, etc and then didn't measure correctly.
Then I used digital kitchen scales for years but have found that they aren't very good for small amounts. I've therefore invested in some that only weigh up to 500 grams, so hopefully more accurate with the smaller weights that I seem to use for epoxy nowadays.
It's amazing how far 60 grams of epoxy goes, especially when mixed with additives.
As per thinwater I normally add additives by 'eye' to get the mix I want.
GHA
26 Jun 2013
Hopefully somewhere warm
Another plus for kitchen scales, weigh some fixed amounts then make a spreadsheet for A/B/total. Even cheap scales seem to be all accurate down to a gram these days.
No so good rolling a bit anchored though...
