Nieuwport Firing Range
bluerm166
29 Sep 2009
I must admit that there are so many lines on the chart along the Belgian coast, many with duck symbols showing nature reserves,that I had not spotted the implication of the 'flame' or explosives symbol on some lines, or imagined that anyone could run a firing range along a coast frequented by so many yachts. Nor did I understand the flemish warnings that I would have heard on the vhf,so I was surpised as I spun along in June ,downwind under half a jib and surfing down the waves at over 7kts and under wind vane control to be approached by a tubby launch with a man holding up a large board directing me to another VHF channel.
I had been aiming to pass inside the Stroombank to enter Ostende so probably just within 2 Nm of the coast.So I was a bit put out (and in disarray) to be suddenly told by a polite but firm lady to take a direct course at 90 degrees to clear the range extending 4 miles out to sea.In fact the wind direction allowed me to continue seaward on a reach in fairly large waves and eventually my request to turn back was accepted.In fact the lady admitted that use of the 4 mile range extension had now been abandoned anyway.Good news for the yacht behind me who had just entered the range where I had.
I must have been lucky passing previously and I wonder if others have had the same surprise.
Champagne Murphy
5 Jun 2011
Suffolk
Not had the problem there although we have been shooed away from Lydd ranges by a tubby man in a tubby boat.
Seems a better option than being shelled!
FulmarJeddo
20 Jul 2007
Home-Sidcup, boat-Lower Halstow, Kent, England
We wandered into that range back in May, heading from Oostende to Gravelines. We were a group of 4 boats and I was the only one with AIS. Three of us decided to go a bit further offshore whilst the other boat took the inshore route. Soon after leaving Oostende we started hearing a vessel Yeddo being called on the radio. My boat name is Jeddo. We commented about the similarity, but it didn't register that a J is pronounced as we pronounce Y. Eventually a different lady came on pronouncing it in English, to which we responded. We were told the range extended 7 miles offshore and should steer 300 degrees. It was only zooming in on the Garmin Plotter we found a reference to a note. A search through the menus got us to the note that said Military Practice area. We reached a row of Cardinal marks that appeared to be the perimeter and one of the other boats tried to get hold of the range again on 67 where we had been communicating with them. There was no response from the range, but Dover Coast Guard picked up the call and asked which range was he trying to contact. Belgium Coast Guard immediately jumped in saying it was in their water and all under control. Shortly afterwards the range contacted us and said firing for the day was finished and thanked us for our cooperation. The boat that went inshore was approached by the patrol boat, but was allowed to continue. Not sure if that was due to us holding up any firing.
johnalison
14 Feb 2007
Essex
Our first return in our new boat approaching Kiel from the East was met with a peremptory "You vill head 350 degrees for five miles or ve vill blow you out of ze vater". Actually, I made up the last bit, but it felt like that.
Lulworth was more polite, though we didn't stray into their playground. Near the end of the day a French yacht approached Weymouth close inshore. The range chappies talking to each other referred to it rather wearily as having taken the 'scenic route'.
NotBirdseye
13 Apr 2019
Wales
Kek, there's a firing range near newport too...XD Under the same sort of conditions
Castlemartin, Manorbier, Penally (Pembroke) and Caerwent (closer to Chepstow than newport but still). Caerwent is usually not a problem due to the type of training they conduct. If you're instructed to take action a chill should run up your spine, it is because Live Firing is or is about to take place. For your own safety, switch on the engine and make all haste out of the area. To be fair, sounds like they messed up and didn't have a proper watch out hence the Training Safety Officer called it off.
If there's no live firing, they generally don't mind you going through.
westhinder
15 Feb 2003
Belgium
The firing range at Lombardsijde next to Nieuwpoort harbour is active throughout the year, except for weekends and school holidays, so not in July and August, for two weeks around Easter and the week of the first of November.
The firing range can be contacted on VHF 67 ‘Sector Lombardsijde’.
When the range is active, it is indicated in the harbour channel on the starboard side when exiting and there is a guard boat near the entrance. Firing can take place in three sectors: small, intermediate and large, and that will determine the detour you have to make.
It is always good to call the range officer, in many cases you can negotiate free passage. They always take a break at noon and close quite early in the afternoon.
All the details are here: https://m.mil.be/nl/zeewaartse-schietoefeningen?mobile_domain_switch=0
Or in the Belgian Notices to Mariners: https://www.afdelingkust.be/nl/berichten-aan-zeevarenden Normally the dates are published in the first NtM of the year.
Tin Tin
14 Jan 2010
Normandy
FYI: Belgian Coastguard website - last item.
Firing exercises seem to be referred to as 'shootings'.
https://gardecotiere.be/en/faq-list?field_faq_type_tid=6
Gargleblaster
16 Dec 2003
Medway, Gillingham Reach
Is that the one just west of Fehrmarn on the right as you come out of Kieler Bucht? If so I wandered into that one in June during an electrical storm when it was absolutely dark at 1600 hours. Had been steering to clear the yellow marker buoys as had listened to the live firing message on VHF. But in the dark the yellow buoys didn't show lights I wandered into the area and when the storm cleared recognised the boat being called at a certain lat/long was me. Was directed to leave the area as I was in a NATO naval live firing exercise. Found the line of yellow buoys again and started to head around them as I was heading for Fehrmarn. Was interested to notice that inside the buoys a Russian fishing boat that I hadn't heard called was steaming along closely followed by a grey gunboat of unrecognisable nationality. Having a VHF conversation with NATO Control is quite exciting.
ex-Gladys
29 Aug 2003
Colchester, Essex
About 2017 we were going to Chatham from Shotley whilst on hols, going down the Maplin edge and OUTSIDE the range we were told to go at least half a mile further east by the guard boat... Having done that, we were quite surprised to see shells landing behind us nearly hitting the Barrow !
johnalison
14 Feb 2007
Essex
Yes, that's the one. It covers a large area and is awkward when passing from Fehmann to Kiel. The times of firing are listed and copies are displayed at nearby marinas such as Laboe and Heiligenhafen. They tend not to fire on Sundays I think. There are also pillars with flashing lights during firing at each end on the shore which are marked on the charts. At least they warn you off. When passing a Polish range near Utske we were told that they don't warn you but fine you after you have passed.
Marmalade
15 Feb 2005
Essex
We must have benefited from the August holiday as we tacked down from Ostend to Nieuwport close inshore last week... must admit - I've never been warned off that stretch of water - maybe I'm always there in July / Aug...
bluerm166
29 Sep 2009
Not the only one then.Certainly adds a frisson to passage planning (otherwise fairly basic along here),with all these advisory dates,which I just missed.Must add a waypoint after the 'belgian flag' reminder - to 'call 67'.Having passed the Zuydcoote,heading NE, you're very likely to be beyond getting a good sight ofthe described warning flags.The dogleg is pretty obvious here.
http://www.sportstracklive.com/track/map#Stourmouth/Sailing/to-Ostend-/single-hand/2579672/full
Many thanks Westhinder for the range info.link.
As for clearing the range quickly ,the point is taken,but if we are at hull speed under reduced jib then we won't go any faster under the engine.
bluerm166
29 Sep 2009
Hoping to get up to Holland this year so planning to avoid another forced diversion out to sea off Nieuwport by planning ahead.
I haven't managed to get into the Belgian Ministry of Defence website (the subsection that is) as kindly listed above by Westhinder but here at least are the dates when they won't be using the range,together with the range phone number.
Koeketiene
24 Sep 2003
Finistère
www.sailblogs.com
Westhinder's link is somewhat out of date.
This is the correct link: Agenda
Alas, in Dutch and French only.
For the linguistically challenged, there is always Google translate. ;)
westhinder
15 Feb 2003
Belgium
Correct.
The principle remains: the Belgian army does not shoot during weekends, school holidays, bank holidays and any other occasion that might conceivably attract people to the beach.
Which is just as well, as it means that we and over 2000 other boats in Nieuwpoort are very rarely inconvenienced.
westhinder
15 Feb 2003
Belgium
Just a reminder, the Nieuwpoort firing range will not be active on the following days:
- all Saturdays, Sundays and bank holidays
- 1 to 16 April
- 29 April to 1 May
- 18 to 21 May
- 27 to 29 May
- 15 June to 17 September
- 28 October to 5 November
- 15 November
- 22 December 2023 to 7 January 2024
