It may be significant that ships operate in a much thicker 'top layer' than we do?Surface water flow is generally accepted as the top layer that vessels operate in. There are various components to this and around the UK, the major cause is of course, tide. Tide streams are given as surface water flow. .....
I don't know how deep the layer is. But it's that top couple of metres that is of interest to us.It may be significant that ships operate in a much thicker 'top layer' than we do?
The top metre and a hlaf where my boat operates is probably pretty stirred up by waves and so much more influenced by wind than deeper down.
We are told to keep in shallow water when punching tides and I think we are all agreed, anomalies aside.It may be significant that ships operate in a much thicker 'top layer' than we do?
Interesting life experience for you at that time.In order to give live tidal streams you need to deploy current meters with a live data feed. That's a lot of hardware to source and maintain to meet the OP's requirements. Tidal diamonds and other stream data were at best obtained by deploying a string of self recording instruments over a month. Observed stream would be correlated with the tidal coefficients. A lower level of accuracy could be obtained by anchoring a vessel and taking a profile of manual readings at 30 minute intervals for 25 hours. If we go back to before my training as a hydrographic surveyor a vertical spar would be released and the drift tracked for about 30 minutes, then returned to the release point and repeated. Predictions would be made from these readings on the assumption that stream was proportional to range at the time of recording.
While sailing I would look for the wake around marker buoys etc. to get an idea of the actual stream.
Yes, it had its highlights:Interesting life experience for you at that time.
Having just got in from racing, I can assure you the deeper water moves faster. We had Hall Hunter as our windward mark, it’s outside the shallow water. The tide rips along out there, but only 100m inside, on the Island shore, is the shallow water. You tack up inshore, then those with limited experience go for the buoy. Wrong. As you get into deeper water, the tide gets stronger, and whilst in shallow water it looks like you’ll make the mark, you suddenly find you’re not making it. There’s a fairly clearly defined line, weed, flotsam marking the interface in tidal speed. You can only round Hall Hunter from up tide.We are told to keep in shallow water when punching tides and I think we are all agreed, anomalies aside.
I think the deeper water has more force but seems to move at the same speed.
A bit like two similar chariots . One with only one horse and the other with two horses pulling. The two horse chariot has more force rather than extra speed
Yes, as the description says, not really any use in "in closed, long or narrow bays" or indeed coastal waters. However, its the closest available to the OP's criteria and could be useful on ocean passages if the vessel has the tech to access it.A 27km grid is a bit useless for passage planning, never mind racing. A difference of 5 metres can be the difference between winning and spectacularly losing around here.
You don’t get tide diamonds in the middle of an ocean chart, so out there I’ll grant you, it’s all you’ve got.Yes, as the description says, not really any use in "in closed, long or narrow bays" or indeed coastal waters. However, its the closest available to the OP's criteria and could be useful on ocean passages if the vessel has the tech to access it.
There is average wind and current information for each month on "Admiralty Routing Charts" and the US equivalent "Pilot Charts". Sets of 12 charts for each ocean. Tidal streams are less important once off the continental shelf and away from land so no need for diamonds. Real time current information would be beneficial, especially for slower vessels, as many ocean currents are variable and have eddies that can not be shown on the average charts.You don’t get tide diamonds in the middle of an ocean chart, so out there I’ll grant you, it’s all you’ve got.
It’s been some years since my last ocean trip. Return to civvy life, Kids, business etc. But I do remember such things, though never had to navigate anything that wouldn’t do 45kn And then very rarely out of line of sight.There is average wind and current information for each month on "Admiralty Routing Charts" and the US equivalent "Pilot Charts". Sets of 12 charts for each ocean. Tidal streams are less important once off the continental shelf and away from land so no need for diamonds. Real time current information would be beneficial, especially for slower vessels, as many ocean currents are variable and have eddies that can not be shown on the average charts.
