PaulRainbow
N/A
If I installed this as secondary filter on engine, would it bleed through after changing primary filter?
Yes, it would draw the fuel through the primary filter.
Excuse my ignorance. What's a pre-filter trap? Is this different from what I think of as a primary filter? Thanks
It is important that the bulb is suitable for use with diesel.
The bulbs used with petrol outboards can go hard in time if used with diesel, and become susceptible to cracking.
It's nothing more elaborate than a clear glass jar housed in a filter like assembly that fit's before your paper filter, it's intended to remove water and any debris from your fuel before it gets into and blocks up the filter. The nice thing about it is it's simplicity itself to clean and replace it: There's a thumbwheel in the bottom of the housing, undo that and the jar slips out. M/T the dirty fuel, wipe the jar out with clean rag, (I normally top up the m/t jar with clean fuel because it's easier than filling an m/t jar with the lift pump) slip the jar back into place and tighten the thumb wheel - don't go banana's on the thumb wheel, I've seen the jar's break when someone as been over enthusiastic.
What I really like about this is the fact you can see at a glance dirt, water and debris, so it's easy to keep your system up and running - no more shocks thru dirty filters.
My last diesel car had a squeezy bulb for priming the filter. It was permanent original equipment and securely mounted next to the filterIt may only be individual preference but I think the squeezy bulb option looks a bit temporary. I prefer the type of housing with a piston that can be securely mounted to a bulkhead.
Mine was mounted satisfactorily. I cannot tell you how because i never had any reason to investigate .A lot of old French diesels had built in primer pumps which can be sourced from a scrap yard for a tenner. With a bulb type one I don't see how you can mount it satisfactorily.
So do I currently, (my boat is a Dufour), but I'm planning to fit double primary filters with a switch-over arrangement. This will entail mounting them higher up, where there is enough space, thus nullifying the gravity effect. My best strategy will be to fit a bulb.I use gravity, a bit of brilliant French engineering.
I've just tried to access Asap Supplies site and received a '403 -Forbidden' message. Does anyone know if their site has been hacked, or is the problem at my end?+1 although my Vetus (Mitsubishi) engine is self bleeding. After a filter change give 10 pumps on the lever on the engine mounted fuel pump then crank for max of 10 seconds, usually less then 5, and it starts. No need to open any bleed screws.
Www.solocoastalsailing.co.uk
