yoda
I am trying to make a new anode which is just a straight bar with 2 fixing holes. I have the old anode which can be reused to provide the steel backing bar, I also have plenty of spare material from old anodes. Question, what is the secret to putting enough heat into the raw material to get it molten. Is the easiest way to break down the zinc to small pieces and start the smelt with a small amount while adding more material slowly before pouring into the mould?
Also apart from sand what other materials can be used to make a cheap single use mould?
Is a regular blow lamp powerful enough to do this?
Thanks, yoda
Thanks, yoda
