ZERO VAT DUTCH BARGES?
emily15559
7 Feb 2007
You may be aware that sail-away or completed Dutch Barges to be used for residential purposes for a number of years were zero-rated. This was taken away by VAT a couple of years ago. But apparently this was the wrong thing to do! A case was brought against the VAT by Colin Stone challenging the VATs interpretation of the law.
Colin won! The outcome indicates that if over a certain size and intended as a residential vessel and is in at least a sail-away condition then it should be zero-rated.
It raises the question if boaters have unknowingly paid VAT in the past for a residential Dutch Barge are they entitled to a refund?
Branson Boats Design supply steel barge kits to many UK builders.( www.dutch-barges.net ) When VAT decided to interpret the law differently and stop zero rating, builders had cancellations. Further, VAT approached the builders for back tax. This even though up to two years ago VATs advice was to zero rate!
As this ruling may save new build Dutch Barge owners and builders many thousands of pounds I thought to raise it on this forum.
Nick Branson
Nautorius
24 Jun 2003
Gibraltar, Small Boats Marina
Hi Nick,
This issue is further complicated by the VAT ruling on commercial craft which again states vat is payable at Zero% on barges. In order to make a Barge Zero Rated you need a hold. So what you do is have the centre of the barge as the living area with freestanding furniture (including galley) and have a large opening sunroof above. In this way it is still classed as a commercial vessel as when inspected all furniture is removed and sunroof/hold roof is opened.
It is a loop hole that I know one small UK manufacturer uses.
Hence I can get a 50ft Barge built and fitted out for just over £200k! and Zero Vatable.
Cheers
Paul /forums/images/graemlins/smile.gif
Sixpence
24 Aug 2005
Here, yah fule
Or alternatively you could buy a 102 ft unconverted dumb barge and convert it yourself /forums/images/graemlins/wink.gif and I just happen to know someone who's selling one /forums/images/graemlins/smile.gif
