Yet another window question...
skipper681
25 Sep 2012
Northern Ireland
I am replacing the plastic windows and I'm doing away with the rubbers, I need to buy some stainless steel bolts and nuts, problem is I don't know what size to get. The Acrylic is 5mm and the cabin is about 6mm, so that is the length sorted, I don't know what width I need or how many, it's a 19ft Hurley with four windows.
Ebay links most welcome :)
Tranona
10 Nov 2007
6mm is rather too big for this job. 4 or 5mm is adequate. You need a nut for inside. Remember to drill clearance holes and use butyl tape to seal.
Poignard
23 Jul 2005
South London
I think 4mm is fine.
My windows are Perspex set into rebates in the mahogany coachroof. They are kept in position by s/s bezels on the outside.
Originally these bezels were secured with #6 woodscrews, and bad splits developed in way of these, where the grain is short. Having repaired these splits I will through bolt instead of using wodscrews (as suggested by several helpful forum members). 4mm countersunk machine screws fit the screwholes in the bezels perfectly so that's the size I will use, with dome nuts inside. There are 12 screws on each window. The windows are approx 14" x 7".
Henry Royce (of Rolls-Royce) said it was much better to use many small fastenings than a few big ones. I think that makes sense.
rob2
23 Aug 2005
Hampshire UK
A line of nuts inside does look a bit Goth - like a studded collar...! If you want a more pleasing finish inside, you could make a simple wooden frame around the window aperture, then you can simply screw through into it. Ideally, each screw should have a nylon washer under its head, the hole should be larger than normal clearance to allow for the thermal expansion of the acrylic, and a second washer between the acrylic and the cabin side to prevent too much mastic being squeezed out. The idea is that the screws are clamping the materials together, but not locating them as that creates point loading and stress raisers.
Rob.
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
This just about covers what has been said above... http://www.troppo.co.uk/odds/Flying%20Fox%20Windows.pdf
