Yet another anode question
I have 4 each side of my hull/keel, 1 each side of my rudder and one each side of the rudder skeg, attached to M10 studs welded to the steel plating.
Deciding how many is a bit of a black art but there was a very informative thread a little while ago.
Would be very surprised if the boat is not already fitted with anodes, although if it is in fresh water they would be magnesium not zinc. If you are not getting problems with galvanic corrosion on props and other bronze fittings (if you have them) there may not be a need for more anodes. As suggested, find out what you have and if you need advice contact Duffs.
