broadcaster
Hi,
I have had a few problems with our Yanmar 1GM10. Firstly the water pump was leaking because the seals had gone, which meant water dripped on the oil pipes which run underneath and are made of steel. Fixed the water pump with new seals and treated the oil pipes for corrosion.
A little while later the long oil pipe fractured on the bend and empties all the oil in the bilge. No problem, got the new pipes (at £92.57). Went to fit them and the bracket which holds the long one on is bolted onto the timing case cover. Anyway a light turn on this bolt and the head snaps off. This was probably caused by corrosion. This meant the timing gear cover had to come off with the fuel pump, water pump, pulley etc to be able to reach the broken bolt. Finally got everything unbolted (no other siezed bolts or nuts) and tried to remove the cover. I then found that the cover has cracked around the broken stud, possible due to the bolt expanding through corrosion or while I was trying to get the cover off.
As the gasket for this cover was already £36 + VAT does anybody know where I could get a second hand cover or a new one at a good price.
This shows how a 5 minute job turns into a very expensive 10 hour job.
Andy
Andy
