yanmar yse8
I have a problem"lack of power" under load, have replaced injector nozzle, filters, bled the system, all ok easy start , runs great out of gear, under load cooling water black sooty deposits, low revs half power, HELP!!!!!!!!!!!!
Change that crappy plastic washer if no joy, benny and a box of swan vestas,or if your really desperate, phone bummpy!!
Thank you fellow NOMAD, it turns out that,that crappy washer is £5.00 but have ordered 2(just in case it gets f****d up).
by the way who is "BUMMPY"?????
rather expensive bit of plastic init?, When you down next to try it?. Looking at the tide tables you need to pull the proverbial finger out. Next time i see bumppy alan , im going to snitch on you!!. Who is he!!. Need to find out how a autohelm works , so will be giving you a ring shortly .Regards to the first mate.
Nomad, Wot is the best way to clean a metal air filter???
Bumpy is spelt like this not "Bummpy"!!! that was the question
