sabresailor
Hi - proud owner of a Sabre 27 since May - need to pu the Yanmar yse 12 to bed for the winter. Managed to find an oil drain plug (bottom right) and water drain tap (quite low on left).
Plan to change the oil - run engine to heat oil & drain out & replace - what oil do folks use in these engines??
Also have been planning to remove impellor, open water drain tap to remove the sea water - do I need to do any more. Possibly thinking of running engine with water intake in a bucket of anti-freeze - is this worth doing?
Is there a published maintenance manual for these engines?
Any other tips re winterising this engine?
Cheers
mike
Cheers
mike
