djyacht
I`ve posted previously about starting problem on my newly acquired boat. Despite long cranking etc could not get it to run. I also realise that I may now have water ingression into the cylinder (there was certainly a sloshing sound.)
Three weeks ago I removed the injector pump and injector and had them professionallly stripped, cleaned and tested.The engine at that point would turn over manually with the starting handle.
Today I went to the boat and found that the engine seem to be locked solid and I cannot get any movement with the handle. (I also don`t seem to be able to rotate the output shaft). I did not refit the injector pump or injector.
I have started to strip off the cylinder head, with the thinking that water in the bore may have seized the piston, although three weeks since last movement makes this seem unlikely, and I`m puzzled by lack of movement at the output.
I`ve read previous posts about seized pistons but would be grateful for any advice.
David
David
