Cloven
/forums/images/graemlins/confused.gif Engine - Yanmar 2GM20F circa 1996 but not put into service until 2004. Very lightly used, probably less than 200 hrs.
Problem is when starting, sometimes it starts first push of the button. Sometimes when the button is pushed the water/oil/charge lights dim but there is no response from the starter or solenoid and it takes another one or more (up to 5 or 6) pushes on the button before it starts. However, it has always started eventually. Once the starter engages, the engine starts immediately and once started never misses a beat. One last thing, it usually starts first time from cold but problem seems to be worse when engine has been run but then maybe cooling for an hour or two. (This may be a complete red-herring but it seems to be the case).
OK - had it looked at or considered by three different mechanics. First reckoned it was a "sticky" solenoid and stripped same at considerable cost. Seemed to help initially still same problem. Problem here is that I can't say for certain that this treatment helped. Second mechanic reckoned to leave it alone as it starts eventually. All well and good but recently I was in an F5 & big swell about to drop the main before entering a marina and it took 4 or 5 pushes before starting. Third mechanic reckons its an electrical problem and may be a poor contact somewhere along the system so there is a voltage drop when pushing the button.
I would appreciate the views of those forumites who know about these things.
Thanks in anticipation of any help.
