vyv_cox
My starter button for Yanmar 3GM30F has gradually become more and more erratic. When the batteries are fully charged the engine usually starts first push but if they are a little low it is something of a lottery as to when it will go, sometimes up to 10 presses before one takes. I have noticed that quite a current flow is being registered on the ammeter, so something is happening.
I have read here that there is a fuse hidden beneath the wiring loom, the wiring diagram in my operator's manual and workshop manulal both show it, 30 A in the heavy red cable that supplies the key switch and the starter button. Having decided that there must be some resistance in the fuse holder I have spent a couple of hours this morning trying to find it, with no success. I did find a surprising number of spade and barrel joints in the white solenoid wire but no fuse in the red. Has anyone found it?
Having opened every joint and connector I could find, none the slightest bit corroded, I put them all back together and the engine started first time. With luck I have solved the problem but I would love to find that fuse.
All major cables, both positive and earth, and their connections, are fine.
