Yanmar starter motor - alternatives?
peterpedro
31 Jul 2010
Hello - and apologies if you've seen this before. My initial thread got a bit lost in time.
I'd be really grateful for any advice pls.The starter motor for my Yanmar 3GM has a bad intermittent fault. I've taken the unit off the boat and checked and tested and found the wiring etc ok and the solenoid fine. There seems to be some problem on the shaft (flat spot??). The unit starts and the shaft turns for perhaps 3 or 4 times, then won't budge until I manually turn the shaft. I'm going to see if it can be serviced, but if I have to replace it, does it have to be a Yanmar marine or are there any alternatives? It does seem that if the word 'marine' is mentioned the price doubles. The starter is a 9 tooth, 1kw (Hitachi) S114-303.
Many thanks.
earlybird
18 Aug 2004
Cumbria; U.K.
Any use?
/cgi.ebay.co.uk/YANMAR-MARINE-STARTER-MOTOR-S1128-/190422414499?cmd=ViewItem&pt=UK_CarsParts_Vehicles_BoatEquipment_Accessories_SM&hash=item2c560f74a3
peterpedro
31 Jul 2010
Thanks Mr Cramp. I placed an order about an hour or so ago, but you're always a bit unsure if you've not dealt with a particular EBay company before. This helps me feel much more comfortable. Thanks for taking the time to respond.
